CBR 600 F4 Oil Leak. !HELP!
Old Aug 24, 2006 | 05:50 PM
Hindle Up's Avatar
Default CBR 600 F4 Oil Leak. !HELP!
I have a oil leak coming out of the number one spark plug fluid drain hole. I replaced the valve cover gasket but it is still leaking. I looked over the new gasket, the cover and down into the spark plug hole with a strong light, still nothing, there does not seem to be any cracks of any nature. I need help please.
Old Aug 24, 2006 | 06:17 PM
Hindle Up's Avatar
Default RE: CBR 600 F4 Oil Leak. !HELP!
*BUMP*
Old Aug 24, 2006 | 07:01 PM
mikequinn's Avatar
The rubber gasket hasnt seated properly
Old Aug 24, 2006 | 11:54 PM
Hindle Up's Avatar
I've made sure of that three times it started leaking before I ever took the valve cover gasket off...Thanks though any other ideas?
Old Aug 25, 2006 | 06:58 AM
mikequinn's Avatar
there is the possibility that the gasket might have got nipped at some time, you really must check it before going any further, then try a smear of silicone sealer on the affected area when you refit it, you must make sure its free from oil though,
Old Aug 25, 2006 | 03:29 PM
Hindle Up's Avatar
I never really thought to make sure there wasn't any oil on it before. I can see that making a difference I will try that. Thanks
ko67
F2 Tech
Sep 20, 2011 10:47 AM
vegas_rebel
Aug 28, 2011 12:10 PM
graysonwittwer
Aug 17, 2011 05:40 PM
amir145
Sep 1, 2010 11:33 AM
airick
Apr 17, 2007 06:58 PM
