CBR 600 F4 Oil Leak. !HELP!
I have a oil leak coming out of the number one spark plug fluid drain hole. I replaced the valve cover gasket but it is still leaking. I looked over the new gasket, the cover and down into the spark plug hole with a strong light, still nothing, there does not seem to be any cracks of any nature. I need help please.
there is the possibility that the gasket might have got nipped at some time, you really must check it before going any further, then try a smear of silicone sealer on the affected area when you refit it, you must make sure its free from oil though,
