CBR 600 F3 Tune up
Old Jul 25, 2006 | 03:17 PM
cbr_nasty's Avatar
Default CBR 600 F3 Tune up
I need to know what kind of oil and how much i use in a 1998 CBR 600 F3, and what size spark plugs and gaps they use or if they are pre gapped. also where is the air filter located and can it be replaced with a K & N type air filter, is there anything else im forgetting for just a basic tune up
Old Jul 25, 2006 | 05:33 PM
kustom98f3's Avatar
Default RE: CBR 600 F3 Tune up
4 qts of oil. NGK CR9EH plugs if I remember correctly. Airfilter is inside the airbox under the fuel tank. K&N can be used. From the questions you're asking I seriously doubt you have the mechanical knowledge to even do this tune up.
Old Jul 25, 2006 | 07:19 PM
cbr_nasty's Avatar
Ok i replaced the air filter with a k&n also got a k&n oil filter but i havent installed that yet i live in new mexico where its gets as low as 20 degrees in the winter and about 105 in the summer so i am wondering what oil to use
Old Jul 25, 2006 | 11:10 PM
kustom98f3's Avatar
Check your manual. Synthetic 10w40 works for the broadest temp range I believe. You'll probably have to change weights for different seasons however. All of the questions you are asking though can be easily found in a service manual and your owners manual.
Old Jul 25, 2006 | 11:11 PM
rocketjoe's Avatar
10w40 should be good. Sounds like you need to down load a service manual.
Old Aug 17, 2006 | 01:45 AM
noslofivoh's Avatar
Where can you download a service manual?
Old Aug 17, 2006 | 07:37 AM
mikequinn's Avatar
10W40 is ok all year round in all climates for the CBR, just make sure you use a good oil like CASTROL Semi synthetic or Fully
always buy the best you can afford and avoid these low buget oils.
The bike will thank you and so will your clutch
Old Aug 17, 2006 | 11:06 PM
spdrmns's Avatar
I found my F4i service manual by searching on google for about an hour or two...lol..my service manual was about 100mb so you will know when you find it!
Old Sep 6, 2007 | 12:38 PM
WAKEnBAKE's Avatar
I know this is an old thread but I figured I'd add my 2 cents - www.stephygee.com has downloadable service manuals... that's where I got my F3 Manual
Congee
May 29, 2014 11:37 PM
stretch_the_apex
Jan 30, 2011 11:58 AM
F4ISmurf
Jun 1, 2010 11:41 AM
red99f4
Mar 4, 2010 10:32 PM
JMart
Jun 29, 2007 08:20 AM
