bike sat with fuel in it for 2 years!
#31
Evo- Is your radiator fan kicking on? The fan should turn on at about 212 if im not mistaken (correct me if im wrong). If so you might also want to check your thermostat to make sure its not stuck closed. I had this issue not to long ago and its easy to swap out for a new one. As for the smoke, if it hasnt gone away by now it sounds like it may be a leak. Ive spilled fluid before and it smoked as soon as the bike was warm, but went away pretty quickly.
#32
#33
yeah the fan is kicking on at around 220 F. but it gets that hot just warming up.. is that normal? also the smoke is gone, but i can feel a lot heat emitting from the top of the engine. but its not smoking anymore. i can also smell a weird non exahst smell comming from the top of the engine..
#34
#35
#36
My bike was similarly 'stored' and what I did to get her going was:
- Flush the fuel system (replaced the gas)
- Oil Change
- Fuel filter change
- New spark plugs
- New air filter
- Cleaned the carbs
- Replaced any hoses that looked like they started to rot
- Cleaned & retaped electrical connectors
- New chain + sprockets (my change was rusted)
- Flush the coolant and replace with new coolant
- Flush & bleed the brakes
- New tires
- Inspected brake pads
Since you have an F4i, do whatever you're supposed to in order to clean fuel injectors. And give it a thorough inspection of all controls. Ride her tender while you two get acquainted
#37
Anything from 170 - 228 is normal operating temps. In stop and go summer temps you will feel the heat in your legs and about 225-228 is normal. On the highway you will see around 170-180 is average.
