battery swap
Old Aug 27, 2007 | 10:39 PM
florida boy's Avatar
Default battery swap
can you put a battery from a honda 600rr in to a honda 600f4i , they are the same year and did not know if you could swap them. and also what is the best to drain the coolant out and replace it.
Old Aug 27, 2007 | 10:44 PM
knightslugger's Avatar
Default RE: battery swap
ORIGINAL: florida boy
I'm guessing it's the same Yuasa Battery... if it fits, use it.
I'm gonna let you re read that and hopefully retype it all so it's less confusing as to what it is you're actually asking here... cuz i haven't got a ****** clue.
Old Aug 27, 2007 | 10:51 PM
not from the battery but from your raditar and replace it .
Old Aug 27, 2007 | 10:55 PM
Dude, are you drunk or are you that bad at the English language...? I have NO idea what you're talking about anymore!
Old Aug 28, 2007 | 03:08 AM
demonchild's Avatar
i think he also wants to do a coolant flush after the battery swap?
Old Aug 28, 2007 | 09:32 AM
Nauree's Avatar
Unscrew the drain bolt from the water pump and the drain bolt on the camshaft?
Old Aug 28, 2007 | 12:20 PM
fishfryer527's Avatar
Does the coolant system needed to be 'burped' ( to get rid of air pockets) will be his next question.
Old Aug 28, 2007 | 08:15 PM
thanx for the help.
estate4life
Dec 4, 2012 11:08 PM
Pedramkhan
May 17, 2012 06:07 PM
Bringingf2bak
F2 Tech
Apr 23, 2010 03:22 PM
jharbinson
Dec 31, 2009 09:23 AM
njdjh2o
Apr 11, 2008 07:20 PM
