alarm/remote start
Old Jan 21, 2009 | 01:16 AM
aj_jensen73's Avatar
Default alarm/remote start
So my friend bought his bike and the old owner gave him a brand new alarm/remote engine starter and said it would work just fine on motorcycles. how would the remote starter work with the kickstand switch and I dont park my bike in neutral so would it have to be parked in neutral? has anyone ever installed one before? I will be installing it on either his bike or mine just to see what its like but if it goes on my bike I am going to just cap the engine start wires cause I have no need for that but I am just wondering if anyone else has done it and how it works.
Old Jan 21, 2009 | 06:01 AM
F4Isvt's Avatar
Default RE: alarm/remote start
the rspart is simple hook up you hot and ground wires and tap into the clutch and starter wire. As for the bike I am not sure. You would have to make the bike believe the kickstand is up and clutch engaged constantly. I personally would not do it. I have remote starts on my cars but I also like for them to be warm in the winter when I jump in. I dont usually ride my bike in the winter.
Old Jan 21, 2009 | 10:15 AM
paulooo's Avatar
ya that seems like a bad idea.. what happens if u leave it in gear and the bike pops...it would definalty move foward enough to break something
Old Jan 21, 2009 | 04:05 PM
BTBTBT's Avatar
it can be done with two relays, however I wouldn't advise you on doing such a thing. Sure, it would be neat, but there are plenty of things that could go wrong.
Old Jan 21, 2009 | 07:45 PM
ya its just not worth it and my bike doesn't take long to warm up anyways so it would not do me anything but entertain me so im not going to put it in.
Old Mar 7, 2009 | 11:30 AM
dementedf3's Avatar
actually you can install a remote start on a motorcycle and it be pretty safe. the only problem you could have is making sure you park on flat ground because of it being in neutral. To use it the bike would have to be in neutral. Remote starts have several safeties to keep them from started when its in gear etc. since the bike has a light for when it is in neutral and a kickstand sensor it should be cake to properly install the alarm/ remote start.
Old Mar 10, 2009 | 12:15 AM
mxman87's Avatar
i have the python 990 on my bike, and i love it. but they do take time to put on depending on the bike the hondas usually have the hardest install. the f4i have a wire that has to see the correct voltage or it wont start its like a security wire so its harder to steal. you have to make a couple bypasses so you need to be good with resistiors and that kind of stuff. my brother installed mine and he has been in the car audio business for 5 years, it took him 8hrs to get it all done. when its done correctly if the bike is in gear it wont turn over, when its remote started if you touch the break or give it some gas it turns right off so someone wont hop on and ride off. its great to see ppl try that. if you have any questions on it just pm me.
Old Apr 15, 2009 | 12:28 PM
nessxp's Avatar
the only thing about that that bothers me is my neutral light dosent always come on, the bikes been beet a bit, and I never trust the light to tell me Im in neutral sometimes it even comes on when switching from frist to second and stays lit
qteter
How-To: Mechanical
24
Nov 11, 2015 06:57 PM
PALUMBOGIO
Feb 16, 2012 08:07 PM
mxman87
How-To: Mechanical
Feb 6, 2012 07:19 PM
__Z__
Mar 25, 2010 09:31 PM
roderickdj
Apr 3, 2008 10:16 AM
