Air/fuel mix screw
Hey there and welcome. Not sure I fully understand your question but it adjusts the fuel and air mix ratio mainly from idle to 1/2 open throttle. It begins with being the major factor at aisle then tapers down as throttle is applied and other fuel circuits are engaged.
hope that helps
hope that helps
i was wondering if it was a fuel adj screw or air adj screw as i believe they are adjusted opposite. Fuel- in less fuel, out more fuel. And Air- in more air, out less air. Hope I explained what I mean. Thanks
