carb adjustment
Old Nov 25, 2005 | 03:31 AM
allday's Avatar
Default carb adjustment
where are the air screws and fuel screws in the carb?and what is the compression spec for a 98 cbrf3?
Old Nov 25, 2005 | 01:35 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: carb adjustment
It's not a riding mower dude. The only screw I know of only adjusts the fuel at idle. All your fuel adjustments will be made by changing jets or needles.
Old Nov 28, 2005 | 10:08 PM
transamlt1man's Avatar
There is a fuel screw that will effect from closed throttle to about 1/8 throttle... somewhere in there. To adjust them you need a special wrench. The screws are on the bottom of the carbs. It is a huge pain in the as$ adjusting them. It is a very tight area. NOTE: Carbs either have a fuel screw or an air screw. To tell the difference, when you back off an air screw it gives the engine more air and less fuel, when you back off a fuel screw it gives the engine more fuel and less air.
Old Nov 28, 2005 | 10:54 PM
doncollins's Avatar
Retired Administrator
ummm.... what's a carb?
Old Nov 28, 2005 | 10:57 PM
Whats a riding mower... I always have to walk [&o]
rocklizzard91
May 4, 2012 03:30 AM
silentknight_turbo
Apr 23, 2007 07:55 PM
streetbikestunta
Mar 20, 2007 04:24 AM
weeble1
Jun 1, 2006 01:19 AM
jimmer
Sep 20, 2005 06:19 PM
