carb adjustment?
Old Sep 20, 2005 | 06:19 PM
jimmer's Avatar
Default carb adjustment?
Hi,
I have a f2 on a 93 plate which has a micron exhaust system , tail pipe only , not full system . When I ride the bike hard and rev it to just shy of the red line and change up , there is a moment of hesitation before it picks up again , this only seems to happen in 4th and above . Could the bike be running too weak ? and if so how do I overcome the problem ? I am also about to change the header pipes , due to corrosion , for the micron set . Will I have to change carb settings for the full system and will it make the problem worse ?
Thanks in advance
jim.
rocklizzard91
May 4, 2012 03:30 AM
silentknight_turbo
Apr 23, 2007 07:55 PM
streetbikestunta
Mar 20, 2007 04:24 AM
weeble1
Jun 1, 2006 01:19 AM
allday
Nov 28, 2005 10:57 PM
