Air/fuel mix screw
Old Aug 30, 2020 | 01:41 PM
Blaktrans's Avatar
Default Air/fuel mix screw
Hi everyone, first I want to thank everyone here for all the help and answers. Can someone let me know if the air/fuel mixture screw on 96 f3 control air or fuel. Thanks again.
Old Aug 30, 2020 | 01:50 PM
Hey there and welcome. Not sure I fully understand your question but it adjusts the fuel and air mix ratio mainly from idle to 1/2 open throttle. It begins with being the major factor at aisle then tapers down as throttle is applied and other fuel circuits are engaged.
hope that helps
Old Aug 30, 2020 | 02:42 PM
Blaktrans's Avatar
hope that helps
i was wondering if it was a fuel adj screw or air adj screw as i believe they are adjusted opposite. Fuel- in less fuel, out more fuel. And Air- in more air, out less air. Hope I explained what I mean. Thanks
Old Aug 30, 2020 | 03:21 PM
Thanks for the explanation. The more you unscrew it the more air is in the system making it leaner
patspiercing
Oct 23, 2018 02:50 AM
Ls1Mx5
F2 Tech
Aug 23, 2013 11:12 PM
IDoDirt
Stickies
May 13, 2011 05:47 PM
quadracer18
Jul 15, 2008 05:43 PM
allday
Nov 28, 2005 10:57 PM
