954 won't start
Old Apr 4, 2012 | 11:48 AM
Anyst8ofm1nd's Avatar
Default 954 won't start
Ok long story short bike hasnt been started in months... Changed spark plugs out and brand new battery. Turn the key everything comes on fuel pump primes.. Hit the ignition bike tries to turn over but that's about it. There is also a clicking noise comming from a relay or something next to the battery across from the fuse box don't know if that means anything can't remember hearing it before. Any ideas?
954 won't start part 2 - YouTube
heres a video from today.. i was running a jumper from a car battery so there is no issue with battery voltage/amps. Any troubleshooting that i can do to narrow down what the problem is? I can smell gas while I'm trying to start, giving some throttle while it cranks. So i don't think its a fuel issue.
Old Apr 4, 2012 | 12:02 PM
74demon's Avatar
sounds like the battery voltage is too low. if your sure that your batteries are any good, check to see how much draw is at the starter, resistance is in the cables, and connections are clean and tight. did the bike run okay the last time it was started?
Old Apr 4, 2012 | 12:11 PM
yea the bike ran fine it just hasn't been started in a long time. And I'm jumping voltage from a car battery that i just took out of my car.. so that shouldn't be an issue
Old Apr 4, 2012 | 03:38 PM
ok been out there all day working on this damn bike.. the injectors are firing, so i pulled the spark plugs to check if they were firing and NADA. No I'm stuck in a bit of a situation cuz i gotta find out why they aren't firing. any suggestions?
Old Apr 4, 2012 | 04:12 PM
74demon's Avatar
how do you know the injectors are firing? are the plugs wet?
Old Apr 4, 2012 | 06:03 PM
had the air box off and looking into the throttle bodies while trying to start and saw the gas spraying in
Old Apr 4, 2012 | 06:22 PM
74demon's Avatar
do the coils have power from the ecm?
pgm-fi fuse good?
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
