929 problem
Old Jul 27, 2005 | 10:34 AM
qwerty9999's Avatar
Default 929 problem
I was driving my 2000 929 yesterday when for no reason it died. I pulled over and noticed that when i turned the key to on I couldn't hear the fuel pump run. I let the bike sit for five minutes and tried it again, this time the fuel pump turned on and the bike started. I didn't have that problem for the rest of the day. Anyone had or heard of this problem and know how to prevent it from happening again?
Thanks
Old Jul 27, 2005 | 02:37 PM
Anubis's Avatar
Default RE: 929 problem
its only a guess so it could be aload off bs, I had a fuel pump that did that twice on 2 seperate occasions on a 400 i had, it turned out to be some crap in the fuel causing blockages.
Old Jul 27, 2005 | 07:27 PM
sirlimpzalot's Avatar
Inspect the fuel filter and add an in line 1 as well...and check routing of the tank vent hose also to ensure that it is not pinched and causing vapor lock
Old Jul 29, 2005 | 11:20 PM
qwerty9999's Avatar
I took the gas tank off and found that the ground wire to the fuel pump was barely connected. I reconnected it and ran an extra ground wire to the frame. I haven't had a problem since.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
