600RR won't start
Old Mar 27, 2008 | 10:15 AM
ebu3sg's Avatar
Default 600RR won't start
I have an 06 CBR600RR that won't fire. Never wrecked or down. Tested fuel pump and battery which are both good. Bike turns over but won't start. The dash has the FI indicator which comes on only after 2-3 times of trying to start it. It does not flash,but just stays on. I can only assume this is a generalization of something wrong with the fuel injection system. The weird thing is just 7 hours earlier I fired it up and rode it into the garage!!!! It has gas.Any help is GREATLY appreciated!
Old Mar 27, 2008 | 10:41 AM
fishfryer527's Avatar
Default RE: 600RR won't start
My F4i flooded by running it for a minute then shutting it off once or twice.
I would try charging the battery overnight and then cranking the throttle all the way open and leaving open when trying to start it. Check your manual for the flooded procedure but I think thats it.If it isn't that then you may have a real mechanical issue.
edit: Check the dopey things too like thefuses.
Old Mar 27, 2008 | 02:15 PM
xtremef4i's Avatar
The plugs could be fouled if you have started it up and shut it off several times with out leiitng the bike warm up...could also be a pinched vaccume line as was the case with my F4i
blownsob
Nov 14, 2011 02:36 PM
The__Rider
Feb 19, 2010 12:57 PM
blaznone
Apr 15, 2009 09:11 PM
burtt9
Jan 13, 2009 02:13 PM
abcorona1
Jun 30, 2006 10:14 PM
