05 600rr won't start
Fuel pump will not prime and starter does not click or turn the engine over. The computer is getting no power. Checked all fuses and relays, BAS has been bypassed, oil pressure switch is hooked up, kickstand switch is good, nuetral switch is good as well. Replaced the starter switch and still nothing. Headlight and gauges all come on and when I hit the start button the lights flicker so it is drawing power. The battery has plenty of voltage and amperage.
Any ideas??????
Any ideas??????
Any ideas??????
Any ideas??????
roll the bike around go threw the grears a lil. like up to 2nd the ndown . do that let it sit for second put it in nuetral and start if it wont start try holding the clutch in while in gear
I had a similar issue with my 05. The voltage was good at the battery, fuses were good, and etc. The symptoms I had was my headlights were out all together and when I hit the start button, no cranking. With some poking and prodding, I essentially had a bad ground. There is a little yellow plug looking thing in the main harness (left side) just behind the tank. If you remove the tape from that, look to see if it's discolored from getting too hot. Mine burned up like the old RR/stator plug in F3's and wasn't allowing all the circuits to open.
