600RR won't start
I have an 06 CBR600RR that won't fire. Never wrecked or down. Tested fuel pump and battery which are both good. Bike turns over but won't start. The dash has the FI indicator which comes on only after 2-3 times of trying to start it. It does not flash,but just stays on. I can only assume this is a generalization of something wrong with the fuel injection system. The weird thing is just 7 hours earlier I fired it up and rode it into the garage!!!! It has gas.Any help is GREATLY appreciated!
My F4i flooded by running it for a minute then shutting it off once or twice.
I would try charging the battery overnight and then cranking the throttle all the way open and leaving open when trying to start it. Check your manual for the flooded procedure but I think thats it.If it isn't that then you may have a real mechanical issue.
edit: Check the dopey things too like thefuses.
