600rr starting problem
Old Aug 10, 2007 | 06:05 PM
wrecked06's Avatar
Default 600rr starting problem
Well after I wrecked my bike I started it like a little bit after (maybe 20minutes) and it had no problem took it to my friends house and started it again and then a couple days later took it home and now the headlight won't start no headlights high or low beam and the fuel pump doesn't even kick on. I checked the fuses and I have no idea what the problem could be at all hopefully someone can help me out with this.
Old Aug 10, 2007 | 06:52 PM
fishnride's Avatar
Default RE: 600rr starting problem
Check the fuses under the seat, if you don't find a bad fuse there - check the fuses behind the left mid cowl.
Also, make sure your battery is fully charged.
Old Aug 11, 2007 | 12:06 PM
bmorrisj's Avatar
kickstand sensor?
spicymeowmix
Jun 17, 2010 08:25 PM
CyberTrip
Jun 17, 2010 08:21 AM
01F4iPlatano
May 20, 2010 06:30 AM
scottiekarate17
May 16, 2010 09:14 PM
GsusFrk
Jul 4, 2007 09:51 AM
