Starting problem - VID
Old Jun 16, 2010 | 06:11 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
Default Starting problem - VID
Listen to this and tell me what you think.
My initial reaction was plugs.
I've checked them 3 times (gaped right), and the coils, they are all good.
Pump is fine.
Gas is good.
Fuses are good.
I let the bike sit without the plugs to dry out a bit, but same problem.
I guess I could order a new set of plugs just to be on the safe side.
She started up initially but sounded like she was running on 2 plugs, then bogged down.
Old Jun 16, 2010 | 08:46 PM
willduce's Avatar
sounds flooded out. maybe pull plugs to let dry out. put them in after a while and try to start with no choke and a little throttle. or the worst thing ever but a time saver......a little snort of starter fluid
Old Jun 16, 2010 | 10:24 PM
yea id guess so
Old Jun 17, 2010 | 03:00 AM
superlund's Avatar
Default try this
try this, for some reason, this always works for me
push the starter for 10 seconds with full throttle and then close the throttle while make sure that the starter is still pressed! and see what happens, good luck
Old Jun 17, 2010 | 06:08 AM
Procrastinator's Avatar
I know it soundz painful, but you need to do a compression test.
To me, it sounded a little like a motor that has jumped its cam timing.
Old Jun 17, 2010 | 01:14 PM
expensive?
Old Jun 17, 2010 | 01:29 PM
andyriot's Avatar
+1
when mine gets like that sometimes its like its flooded so ill try to start it with full throttle and it usually clears it out and starts up fine after that.
Old Jun 17, 2010 | 02:12 PM
Speedemon636's Avatar
Sounds like an operator problem to me lol jk Well from what I can tell, it sounds like it's trying to completely fire but sounds like it's just getting a little fuel so it's popping. The spark should be ok unless you can tell that some plugs aren't firing. Does it smell flooded?
Old Jun 17, 2010 | 02:16 PM
Wouldn't it be easier to just check the timing if that's the suspected problem?..
Old Jun 17, 2010 | 02:24 PM
dont know how to check the timing, but looks like 2 spark plugs are flooded, 1 is about half as wet and the 4th is completely dry.
