2002 cbr f4i ignition button question (custom gokart application)
Old 02-13-2012, 09:42 PM
dying2live900's Avatar
Default 2002 cbr f4i ignition button question (custom gokart application)
I apologize up front if I am posting in the wrong section, I am new to the site (which so far has been quite interesting and helpful) and a little unsure if this is the proper section.
I recently decided it was the time to install a cbr engine on a gokart. I swapped everything over from my 2002 cbr F4I and am very close to being finished.
MY QUESTION: I used all of the stock ignition parts that were on the bike. I recently purchased an aftermarket push button start to replace the factory thumb push button. when I took the button off the cbr I realized there are 4 wires that go to the one button?!?!?! two of the wires touch when the button is not being pressed and the other two that turn the engine over when touched or button is pressed. Also the button is made so that when it is pressed it disconnects the first two wires only until to release the button then it reconnects them ..... what are these wires? I couldn't find anything anywhere. will I be able to install the aftermarket push button?
UNIVERSAL PUSH ENGINE STARTER KIT SWITCH WITH BLUE LED HONDA ACURA INFINITI | eBay
Old 02-13-2012, 11:47 PM
Acespad3's Avatar
i found this in another cbrf thread and thought it might help.. it diagnoses trouble starting and the second post talks about the properties of the kill switch with some detail to the wiring. good luck!
cbrf link
Old 02-16-2012, 12:38 AM
FIGURED IT OUT!!!! After just messing around and touching wires i found that the two wire in from are for the head light and disconnect when you press the button the give more power to the starter.. the two that touch when the button is pressed are obviously related the the starter... i guess you could use those two headlight wires to your advantage if you wanted to do an on/off headlight application.
hoppa2k6
11-06-2010 08:37 AM
jpierc10
03-11-2008 08:15 PM
tollfree969
11-15-2007 05:00 PM
kingmal
05-30-2006 08:11 AM
Quick Reply: 2002 cbr f4i ignition button question (custom gokart application)
