12 volt accessory plug help
Old Dec 20, 2006 | 10:09 AM
cbennett5199's Avatar
Default 12 volt accessory plug help
Any advice on how/where to hook into 12-volt power temporarily (e.g., to use my tire pump) in my '98 F3? It was so easy on my last bike, as it had a couple of leads sitting there for this purpose. Any suggestions are much appreciated. Thanks!!
Old Dec 20, 2006 | 12:20 PM
woot's Avatar
Default RE: 12 volt accessory plug help
First you should have a fuse.
Run the lead from both battery terminals - fuse the power side.
To make it even more slick, put a relay on the power line, with it being switched by the headlight. Then the accessory lead will only work with the bike turned on.
woot.
If this is a one off project, and you want to be somewhat safe. Disconenct the battery from the bike - leave it in the bike is fine - put gator clips on the wires dangling from the accessory plug - connect it right to the battery.
jp_greenville13
Dec 9, 2010 06:49 PM
revilingfool
Oct 25, 2010 04:10 AM
skip954
Jul 28, 2009 02:54 PM
Cornholio
Jul 3, 2008 07:06 PM
f4iman
Mar 2, 2008 11:54 PM
