04 not charging--stator or volt regulator?
im not getting a charge on my 04 what are the tests for the stator and the voltage regulator. so i can isolate the problem. also if anyone has these f/s. thanks for the help. any one with a service manual it would help also.
There is a thread on how to do this in General Tech and How To's.
you should also note that those bikes have a recall on their charging system. Assuming that you have never changed anything, you will need to change the flywheel,stator, and possibly the recitifier. Honda was doing them free to all owners, I dont know if that is still going on. Just a heads up that it is very common on those bikes
Ditto ! I had the same bike with the same problems and had to change the stator and the rectifier. They tend to go at or around 10-15k miles as I think mine at the time about 18k miles so it held on for a bit. After the replacements were completed, it was running so sweet even with all the miles. Good luck !
ive talked to the stealership and they claim no such recall or any info that there ever was one. oh well $130 got the new stator in and running strong. now gotta do fork seals maybe tomarrow if i got time. thks
You need to go back to your dealer and have them call Honda, i have a 04 and the stator went out 3 weeks ago and i called them they said yes its covered bring it to us. I just got it back last week. Your dealer lied to you and if you need more resources PM me and i will get you the info.
