9 volt to PCIII?
Old Mar 2, 2008 | 10:11 PM
f4iman's Avatar
Default 9 volt to PCIII?
I read that in order for your computer to read your PC, you need to plug a 9V battery up to it, if it isnt on your bike. Well exactly how/where do you do this? Thanks.
Old Mar 2, 2008 | 10:25 PM
doncollins's Avatar
Retired Administrator
Default RE: 9 volt to PCIII?
It's an adapter you buy for your PC III so you can take it into a desktop PC and program it if you don't have a laptop. The adapter plugs into the PC III like the normal harness does, but only has two wires that you connect a 9v battery to.
Old Mar 2, 2008 | 10:26 PM
randyjoy's Avatar
It comes with a special connector that you plug into the PCIII and connect a battery. It connects onto the 10 pin connector.
Old Mar 2, 2008 | 10:43 PM
doncollins's Avatar
33 seconds faster... you should have taken that typing class in high school
Old Mar 2, 2008 | 10:54 PM
f4iman's Avatar
Does anyone know which two pins in the 10 pin connector are the ones I can just quick hook to?
Old Mar 2, 2008 | 11:54 PM
Icefox's Avatar
I don't think I'd try to pick out the two pins that you need to provide power to, finding someone that has the adapter would probably be a lot easier or you could buy a replacement one. The adapter isn't listed on Dynojet's website, but they do have a number on there that you can call to order parts not found on that page, I would think that they would still have PCIII parts availableeven though they don't make it anymore. The sales support # is: 1-800-992-4993!
jp_greenville13
Dec 9, 2010 06:49 PM
revilingfool
Oct 25, 2010 04:10 AM
skip954
Jul 28, 2009 02:54 PM
Cornholio
Jul 3, 2008 07:06 PM
cbennett5199
Dec 20, 2006 12:20 PM
