05 1000rr troubles
Old May 27, 2008 | 05:38 AM
oliver0618's Avatar
Default 05 1000rr troubles
I have aquired an 05 1000rr that has been wrecked. It is euro spec but recently parts have been converted to us spec. Got new wiring harness, bank angle, headlights, cluster, and ecu. Hooked everything up...... the fuel pump wont kick on. I can hard wire with jumpers straight to battery and it kicks on but still won't start. Checked fuses and relays with no luck. I checked (with test light) voltage at fuel pump and the light is very dim. Anyone have any ideas? I would appreciate any help.
Old May 27, 2008 | 11:31 PM
Onarom's Avatar
Default RE: 05 1000rr troubles
Did you check the relays in the sidestand and killswitch? Are you trying to start the bike in nuetral? Tested that battery? How many miles on the bike?
BTW- you didn't hardwire your bikes battery from a car battery, did you? I have heard that doing that can create serious problems.
sjona2011
Jun 3, 2012 08:20 AM
GUSGUS
Jun 8, 2011 10:21 PM
stix818
Sep 2, 2008 11:43 AM
brandon k
Aug 22, 2007 05:09 PM
1badf3
Feb 3, 2006 04:32 PM
