04 600rr will not start
Old Mar 7, 2009 | 12:55 PM
blaznone's Avatar
Angry 04 600rr will not start
when i put the key in it used to make a buzz sound im thinking it was the fuel pump kickin on now i have no buzz is there a fuze for the pump???
Old Mar 7, 2009 | 07:43 PM
justasquid's Avatar
Is your bike not starting?
yes, there is a fuse specifically for your fuel pump.
If the pump is working, you can hear it like you said. it will be a slight humming noise that last around 2 seconds.
Old Mar 7, 2009 | 11:26 PM
blaznone's Avatar
Angry
ya the bike will not start but it will turn over the gauges all work i just dont have the buzz humm sound i found a fuse box under the left fairing it has five fuse in it but they are all good i pulled them all out and looked at all of them is there a different fuse box on the bike i just charged the batt. if that helps and i tryed to hook it to my car to see if it would jump but it would jumt turn over still with no fire
Old Mar 8, 2009 | 12:45 AM
justasquid's Avatar
You may want to check your bank angle sensor. thats the only sensor I know of that will shut the fuel pump off. Its located behind your headlight between your headlight and the fairing stay. I would just make sure its plugged in. I've never heard of them failing for no reason. It usually takes a pretty hard crash to ruin them.
I think there is a fuel pump relay under your seat. you may want to find an online service manual and it should be able to tell you how to check the relays and sensors.
this has been a good source for me in the past. you should be able to download a service manual in pdf format here:
http://hondatech.info/downloads/Moto/CBR/
oh yeah, You really shouldnt jump your bike with a car. Your bikes electrical system is a lot lower amperage than what a car puts out. You can easily fry components from doing this. If your battery is dead, I would suggest getting a low amp battery charger.
If you dont have one, I would suggest getting a mulitmeter. A cheap digital one will work just fine. I would start by making sure you have power to the fuse block, then to the relay, then to the pump.
Old Mar 11, 2009 | 04:01 PM
FlatTire's Avatar
Disconnect the fuel pump connector and turn ign switch on while measuring the voltage between the terminals. If you have voltage there then you have a bad pump. If not then check your fuses, fuel pump relay, bank angle sensor, etc.
Old Mar 11, 2009 | 08:07 PM
blaznone's Avatar
thanks for the help i will try that tom. and let you know
Old Mar 22, 2009 | 02:34 PM
hondacbr600rrJACK's Avatar
Default Where is the fule pump relay
03 cbr 600rr that has no power going to the tank.
It was down and i put a used motor in the bike, got it all ready to go and
it turns over but it wont pump fule. I might be missing a part or something idk but i
think it might be a relay or something, but idk where to look HELP
Old Apr 15, 2009 | 09:11 PM
blaznone's Avatar
ok well i know its been awhile but i checked the fuse and its good i changed the fuel pump and i still have no buzz where is the relay on my bike
blownsob
Nov 14, 2011 02:36 PM
The__Rider
Feb 19, 2010 12:57 PM
burtt9
Jan 13, 2009 02:13 PM
ebu3sg
Mar 27, 2008 02:15 PM
abcorona1
Jun 30, 2006 10:14 PM
