95 cbr f3 wont crank over
What kind of shape is the battery in? Did this start all, of a sudden, or gradually got
harder to start? If you haven't already, pull the battery, go to Autozone, etc and have
it tested. After eliminating the battery, it get's a bit tricky. Could be relay, bad starter
ground, bad starter. I'd check all of the connections/wiring as the next step, if the
battery is good.
Ern
battery is good.
Ern
