95 cbr f3 wont crank over
Need help I have a 1995 cbr f3 and it won't crank ... Just makes a clicking noise by the starter .. I made sure the engines wasn't locked up .. idk what else to try
What kind of shape is the battery in? Did this start all, of a sudden, or gradually got
harder to start? If you haven't already, pull the battery, go to Autozone, etc and have it tested. After eliminating the battery, it get's a bit tricky. Could be relay, bad starter ground, bad starter. I'd check all of the connections/wiring as the next step, if the battery is good. Ern |
