CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
wont crank
Old Jun 17, 2009 | 01:43 AM
drift's Avatar
Red face wont crank
just got a used cbr1100xx 2001 model couple of months back, its been packed for 5months, tried to start after all checks, but failed to start.the dash board lights up but the bike would not crank.need some help.a friend thinks its the brain box.
Old Jun 19, 2009 | 11:03 AM
Dean0's Avatar
Check the 30 amp fuse under the seat
The "brain box" - or ECU would not stop it cranking - it just wouldn't run
Old Jul 27, 2009 | 02:36 PM
blkbrdrydr's Avatar
Yeah definately check the fuses and make sure the run/stop switch is functioning and make sure the battery is fully charged. 'Bird's are known for stator's and r/r's that cause these kind of problems too. Hope you get her running, cheers.
Old Jul 30, 2009 | 07:45 PM
skapan's Avatar
Try the simple things first. Is it in neutral, and is the neutral light on? If there's no light, you can still start it if you hold in the clutch and the sidestand is not down. If there is a neutral light and no crank check the stop button on the right handlebar. If it's off, then next suspect is the starter relay. You can short it out to see if it will crank.
All this supposes that the battery is nice and fresh. If the voltage is low (under about 11.6v I can't remember) the bike will not start. If you're not sure try all this with a known good battery.
Hope this helps.
VR6T
May 6, 2018 08:17 PM
ndscbrf3
Dec 12, 2011 05:16 PM
thecoop20
Aug 12, 2011 01:20 PM
MeanGreenZ71
Mar 14, 2011 07:54 PM
mralbdamminc
Apr 10, 2009 11:27 PM
