White Smoke on Startup
Old 04-07-2008 | 01:09 PM
krobberts's Avatar
Default White Smoke on Startup
I get a little bit of white smoke while my bike is warming up. It doesn't start right away when I start the bike either. It goes for about 20 seconds with nothing, and then I get some white smoke. Once the engine drops from the 2k rpm warming up down to the 1k running range, it goes away again. Is that normal?
Old 04-07-2008 | 01:46 PM
atvrider07's Avatar
Default RE: White Smoke on Startup
its just cold out. just like how cars put out white smoke when it's cold. Unless it keeps doing it even when its warm outside or your getting coolant in ur oil you should be fine
Old 04-07-2008 | 01:49 PM
zeit00's Avatar
Yep.. Hot exhaust will pull in moisture from the air and then condense. It will take the exhaust to get warm again for it to evaporate.
Old 04-07-2008 | 03:21 PM
honda502's Avatar
+2 on that. It is condensation. You can tell because it disappears almost right after coming out of the exhaust. Every bike I have owned, except the cruiser, did that.
Old 04-07-2008 | 08:18 PM
krobberts's Avatar
I have a buddy that has a 900 RR, and his doesn't do that. It also did it the other day when it was about 60 out. I also have a friend with a 600 Ninja, and his doesn't do it either. I am not really concerned about it though, it runs fine and I just changed my oil which had no antifreeze in it. I will keep watching as it gets warmer and see what happens. Thanks for the help.
Old 04-10-2008 | 01:43 AM
Fort Collins's Avatar
ya nothing to worry about. it's when you have black smoke you need to worry.
Old 04-11-2008 | 03:06 AM
Niquie F4iChica's Avatar
ORIGINAL: Fort Collins
haha yeah and blue smoke not good stuff.
mj_wils1970
06-20-2008 05:37 PM
ampfp
12-14-2007 06:19 PM
blackey
02-11-2007 06:44 PM
sceptre
08-07-2006 03:16 PM
QuikSilver
07-18-2006 05:38 PM
Quick Reply: White Smoke on Startup
