where is radiator fuse?
Old Jul 1, 2006 | 02:58 PM
fredtheplant's Avatar
Default where is radiator fuse?
my radiator fan doesn't kick in. where is the fuse? i checked the fuse box but i don't see anything that indicates "radiator fan". all the small fuses in the fuse box, the fi fuse, and the main fuse look fine.
when i idle, the temp rises to 250+. please help...
Old Jul 1, 2006 | 03:14 PM
01600F4i's Avatar
Default RE: where is radiator fuse?
mine went out and was right there. Not sure how you're missing it. Pull the seat, in the fusebox right by the battery right?
Old Jul 1, 2006 | 04:00 PM
is the fuse labeled "radiator fan"? in any case, all the fuses in the fuse box are good. what should i check next? and how should i check it?
Old Jul 1, 2006 | 11:08 PM
Turboedsupe's Avatar
Its labeled fan and its the second one from the bottom its a 20 amp fuse. There is a sensor on your radiator right above the lower radiator hose makes sure its connected and the harness thats mounted on the fan also. If all connections are good and your sure the fuse is good and the fan doesnt kick on at 228 then either jump the sensor wire to a ground or take the fan off and hook it straight up to the battery to see if the motor blew
Old Jul 3, 2006 | 03:00 PM
thx for all the help. i found the problem. the wire to the radiator wasn't connected. i must have disconnected it somehow when i was wiring other stuff.
weston123
Apr 30, 2013 06:30 PM
Cytotek
Jun 16, 2010 11:10 PM
Jiggle_The_Handle
Aug 30, 2009 12:57 AM
sasakiman
Oct 29, 2006 01:28 AM
ox.
May 26, 2006 12:13 AM
