where is radiator fuse?
my radiator fan doesn't kick in. where is the fuse? i checked the fuse box but i don't see anything that indicates "radiator fan". all the small fuses in the fuse box, the fi fuse, and the main fuse look fine.
when i idle, the temp rises to 250+. please help...
Its labeled fan and its the second one from the bottom its a 20 amp fuse. There is a sensor on your radiator right above the lower radiator hose makes sure its connected and the harness thats mounted on the fan also. If all connections are good and your sure the fuse is good and the fan doesnt kick on at 228 then either jump the sensor wire to a ground or take the fan off and hook it straight up to the battery to see if the motor blew
