Valve job now no start
#31
What I suspect is that the intake valves are open on the compression/exhaust stroke when the piston is going up.
If it's one cylinder, then it's a valve adjustment, seat problem, burned valve, or flat exhaust lobe issue. They didn't leak when you had it apart, so the valve and seat are most likely alright.
If it's all 4, then it's a cam/crank timing issue.
Have you looked at the cam lobes to see if they are going flat?
#32
https://cbrforum.com/forum/f4i-main-...02-f4i-121020/
im reading this thread.. and the guy recommends that you rotate the engine 4 rotations and recheck if the markings a still lined up. ill open it up again..and see.. ugh
#33
#34
it fired up! finally! i just need to put the exhaust together and add some coolant.
long story short...so the cam rods have these markings... curves ..slots.. that are supposed to be lined up with the markings/curves of the valve cover thingy. once i figured that out, I was able to readjust all the valves properly. Tomorrow, I will put everything together and hopefully...get to ride it. RoaR!!!
JayBoCC2
06-23-2009 10:23 PM
