urgent! headlights just stopped working
Old Mar 27, 2012 | 05:04 PM
Wants a CBR's Avatar
Default urgent! headlights just stopped working
01 model year, stock. Were working on my way home a couple hours ago. Went for a ride, just now and noticed my high beam light wasn't on. Looked closer and no headlights. Fuse is fine, swapped it out anyway and still no headlights. Everything else works fine, and they are plugged in. Please help me as I'm am down to this being my only transportation and its dark when I leave for work.
Old Mar 27, 2012 | 05:09 PM
74demon's Avatar
pull the bulbs to see if they burned out. if both bulbs are, i'd be looking at the charging system to see if its over charging. the r/r may be applying to much voltage through the system.
good luck
demon
Old Mar 27, 2012 | 05:37 PM
High beam indicator flickered on startup, shut it off and fired it up again and they worked. I guess there is a wire for the headlights on the throttle side?
Old Mar 27, 2012 | 05:39 PM
3v1lj03's Avatar
the headlight is connected thru the starter button could be causing your problem mine did that
estate4life's Avatar
February 2012 ROTM
Is there a headlamp relay??
Old Mar 27, 2012 | 05:41 PM
74demon's Avatar
check the starter switch, inside the housing.
Old Mar 27, 2012 | 05:42 PM
MadHattr059's Avatar
The headlights are on a relay that turns them off when the starter engages. Thus assuring the starter/ignition gets sufficent current to do their job.
Check the connectors to the headlights and follow them back to through to the battery, looking for any loose, corroded, or faulty wiring issues.
Good luck, Ern
Old Mar 27, 2012 | 07:06 PM
gotcbr's Avatar
Wants a CBR,
While this may or may not be your problem...
The starter switch in the F4/F4i models are prone to this problem. Be sure that your starter switch is returning properly after start up. If its not, spray some wd40 in there & work it loose.
Old Mar 27, 2012 | 09:50 PM
The switch seems to be working properly and the wires look good. Am I going to have to loosen the cables at the throttle bodies to get a good look at the kill switch wires? As it sits I can't get in there.
What does r/r stand for?
Where is the relay?
Old Mar 28, 2012 | 08:53 PM
An01InAZ's Avatar
Mine did the same thing for a long time. I had to ghetto rig it to have 1 beam on. I would look very very carefully in throttle side box containing 4 wires. It may be loose, but not detached. If 1 wire is loose they won't turn on. I was fooled thinking they were attached and poked it with a screwdriver on the wire and it wiggled. If that's not the case possible ballasts went out if using HIDS
MrCBR10RR
Sep 1, 2011 11:33 PM
johnnycrash
May 21, 2010 09:04 PM
jnmacd
Jun 17, 2009 10:54 PM
KLO
Nov 17, 2008 09:01 PM
KLO
Nov 16, 2008 01:51 PM
