Help, Urgent 929 with no headlights
Ok so I rode to work last night, parked the bike, left work to go to the store to grab a snack around 7pm, came back parked the bike.
Fiddled with some suspension settings around 12am, went back inside.
Came out at 4am to head home and No headlights. Tail and brake light work fine.
Exactly what is happening is I turn the igition to on, and my signal lights come on, like marker lights, but will not flash if i use the switch.
The instrument panel is working but is not illuminated! Heres the kicker, if i hit the starter switch the panel illuminates, but only while the switch is pressed. If i put the kill switch to the no run position and hold the starter button the gauge illuminates and the signals go out as normal, one side will flash and if i try the other it makes the flasher buzz.If I unplug the signals, the gauge will not illuminate at all. Its Fuc-ked
I have check the starter switch and it is good, I have checked the ignition switch its good, checked all the fuses, all are good. I am Tired, been up since 11am yesterday it is now 7am today, and i really just want to get this fixed as i have to be back at work for 6pm.
If anyone could give me a copy of the Electrical schematic it would be greatly appreciated.
I road home in the dark with no headlights and it was not fun!!!
Thanks in advance, Bed time!!
Truly sounds like a ground issue....the schematic is in the service manual, which should be right here.... http://www.mediafire.com/?m4nmv23y2ew good luck!
Ok so looks like the issue is with the Ground bus connector in the main harness on the right side of the frame, I was measuring a 2.5ohm resistance between the sub connector ground wire and the chasiss ground, and i found the connector. Its all burnt and the tape is peeled away.
I didnt have time before work but ill take pictures when i take it apart tomorrow.
Definitely do take pics and post if you can, it may be a common problem area thats pics would help others! Good find
