Urgent clutch help needed
Old Jun 14, 2010 | 06:43 PM
mxjake387's Avatar
Default Urgent clutch help needed
Hey guys im new to the site and needed some advice.
I just got a 2006 f4i that needed a clutch, i ordered a barnett clutch kit with steels and fibers. I put it in the other night and for some reason i had to adjust my cable all the way out to get any resistance in the lever when before it was fine with the cable all the way in, and it still is not disengaging 100%. When i click it into neutral the bike still pulls a little and vibrates. My question is at the bottom of the basket there are two small metal rings one is concave and the other is not, does it matter which order/direction these go in? what else should i check?
Thanks alot!
Jake
Old Jun 15, 2010 | 12:04 AM
bwayers's Avatar
yeah it matters
did you soak the fiber plates in oil over night before you installed them?
did you use a torque wrench on the pressure plate bolts?
i don't have my manual here with me, i'll get back with you tomorrow and let you know how the 2 rings go in
Old Jun 16, 2010 | 03:53 PM
mxjake387's Avatar
yes i soaked the plates and i torqued the bolts down to 9ft lbs.
any info you have would be great.
Old Jun 16, 2010 | 09:34 PM
cbr900racer77's Avatar
That's the judder spring and seat. They basically help with clutch chatter. The larger side of the concave one faces the clutch cover, the flat one just fits over the concave one. I'd take the Barnett's and measure the thickness and compare with your manual. I'm not much on Barnett's clutches for that very reason. I bet they are thinner than stock by a few thousandths, and that definitely matters. Did one of the Barnett fibers have a larger I.D. than the others? If so, that one goes in first. It's larger on the inside to go over the judder spring.
Mustafa Jack Tosuncu
Dec 11, 2013 07:55 AM
riz
Mar 28, 2010 12:13 PM
ikhatib
Aug 15, 2009 02:14 AM
desperado
Aug 8, 2008 09:15 AM
chrisboothe
Nov 26, 2006 08:42 PM
