Urgent help needed ! scorpion stubby
just get the pipe and jets
Short answer is yes it could do damage to the motor.
long answer: If you are going from a stock exhaust to a more free flowing exhaust without adjusting the jetting you could be creating a lean running condition. Most bikes are more lean than they should be from the factory to help pass newer emissions regulations. A lean running ( more O2 then Fuel in the Air/Fuel mixture) engine will create more heat specifically in the combustion chamber, exhaust valve and header pipe. The Jetting will richen up the Air/fuel mixture to ensure balance within a more free flowing system. jettign should be checked after any exhaust or Airbox mod unless the manufacturer specifies that no jetting is required. Without a Dyno tune or manufacturers directions on the amount of jetting its just guess work.
My advice is follow the pipe's installation recommendations or in case of buying a used pip off ebay get the Dyno guys to setup the jetting. Have the carbs/throttle bodies synced while your in there.
Psy
Psy
Are you the original owner? Are you currently running an aftermarket Exhaust?
if so richer jetting may have already been done. It would be close if that was the case. If not your local shop could just put the jet kit in. It would be close enough that you should be ok. Dynojet has kits with general guidelines for intake and exhaust mods. Just ceck out the Dynojet website and look for information on the pipe's manufacturer's website and see what they recommend for jetting. All this info will get you close enough to avoid any damage. A dyno with a exhaust sniffer is the only way to get it dialed exactly. Put the bike on a truck and make a little road trip out of it
psy
psy
