undertail cutting
Old Dec 15, 2008 | 07:48 PM
VTcbr's Avatar
Default undertail cutting
Out of all the undertails i've seen, the hotbodies looks the best to me. It's the sleekest looking and to top it off it has led's which i think makes it pop. I've got an '01 f4i and i'm close to pulling the trigger and buying one. The concern at hand is cutting for the install. Has anyone here every personally installed a hotbodies undertail and have a story to share about it-greatly appreciated.
Old Dec 16, 2008 | 10:11 AM
ffingers's Avatar
Registered Users
Default RE: undertail cutting
i have a hotbodies undertail and like it, i am getting a different one for a new look but that's besides the point...
as for install, the directions are a little sketchy just because they are in black and white and sort of hard to see....do a search for hotbodies undertail f4i install...some guy did an install with a ton of pictures and it helps...it's real easy to do, not hard at all....most frustrating may be repositioning the trunk lock only because the area to screw in is very small...
all-in-all, if you are decent with your hands, shouldn't take you more than 1.5 hours....if you take your time and do it right....
Old Dec 16, 2008 | 12:12 PM
redzintimidator's Avatar
ill be writing up an install how to hopefully this weekend...i got the pimpbike undertail that reuses my stock taillight
Old Dec 16, 2008 | 03:30 PM
StrikeAnywhere's Avatar
plenty of info for this using the search feature. I think I wrote my hotbod install up a few months ago, you can check my previous posts. LEDs on my hotbod undrtail are pretty dim by the way. I usually rep forum member 'stephens' undertail whenever someone asks about good looking brand.
Old Dec 16, 2008 | 10:42 PM
hondajunkie's Avatar
Official Welcome Crew Junkie
I installed an ALtezza Hotbodies undertail on my bike about 4 years ago and is a good piece. The paint started chipping from road debriswithin the 2nd year but that was expected.
Yes cutting the rear fender to make it fit correctly is a little tricky but just follow the directions and youll get there.
Like ffingers stated, the trunk lock can be abit tricky, I had to position mine backwards from where the directions stated, but figured it out.
Heres a pic
cbrdevil32
Mar 9, 2013 09:47 PM
bcouncill
Dec 7, 2008 08:02 AM
clockworkcbr
Dec 21, 2007 06:36 AM
Heretic
Feb 2, 2007 03:59 PM
holly
Mar 20, 2006 05:05 AM
