Track Prep and fuses
Old 10-03-2007, 12:45 PM
Jaybird180's Avatar
Default Track Prep and fuses
Isn’t there an easier way to prep for the track? I pull my fuses for all my lights and realize that my gauge lights aren’t on, and I say OK no biggie. Then I crank the bike and notice that I don’t have a tach, “I can’t ride like that” I think to myself. I notice that the fuse for the rear is the same circuit for the gauges. So I unplug the white, blue and orange harness at the rear, still have rear lights. It a mother to put them back in with my large hands but I suck it up and remove the bulbs.
1st Q: What are those 3 harnesses for?
2nd Q: What’s the easier way to do this?
Old 10-03-2007, 03:26 PM
Default RE: Track Prep and fuses
Can't you just tape over your lights?
Old 10-03-2007, 03:39 PM
Yeah, I also wanted to know what is the easiest way to disconnect all lights.
You can tape them, but they could burn the tape.
Old 10-03-2007, 04:07 PM
axsys's Avatar
ORIGINAL: Daffy472
if you put tape over any light that is still on, it will burn the adhesive onto the light and will be really hard to get off. as far as unplugging the taillight, couldnt you just pull the bulb connectors off without having to pull the bulbs out? same goes for the headlight....
Old 10-03-2007, 04:16 PM
thomasintexas's Avatar
ummmm since when are you required to remove your brake light?!?!?! thats like THE ONE they make you keep....im lost....
headlights yeah....disconnect the harness and put a resistor in place of the bulb in your new harness, yoursystem will think everything is in perfect working order, then put on your race fairing...
you really gonna ride your street bike on the track? if you race you need two bikes realistically....of foot long frame/swingarm/tank/windshield sliders...lol...
Old 10-03-2007, 04:28 PM
Tahoe SC's Avatar
you shouldn't be looking at your tach when on the track...pull that fuse out!
Old 10-03-2007, 08:29 PM
rolandk's Avatar
Heres what I do:
pullthe 10A headlight fuse and the 10A turn/stop/horn/pass fuse
pullthe front turn signal bulbs
remove the rear turn signals completely
unplug the 2 rear brake light wires
remove the license plate
Old 10-03-2007, 11:57 PM
Jaybird180's Avatar
ORIGINAL: Tahoe SC
True that most of the time you're using engine sound. I tape over speedo though.
I pulled all the fuses that were lights related and then put the gauge one back in. It runs ALL the gauges. I think I may need oil, fuel, etc warning....ya know just in case.
Why couldn't that be on it's own circuit, huh Honda?
pmcg
07-07-2014 11:29 AM
Randygus
11-01-2012 06:16 PM
90cbr600f
How To: Paint and Body
09-16-2012 05:16 AM
RayBos
07-12-2011 12:50 PM
89cane
03-26-2008 09:47 PM
Quick Reply: Track Prep and fuses
