tip over sensor
Old Mar 22, 2021 | 04:21 PM
Tucker Bean's Avatar
Question tip over sensor
hey guys my 2001 currently will not even start up the fuel pump, I tipped it over the dumbest way possible I was at a stop sight went to turn left and gave it just a little to much throttle and just spun around and it hit the ground not hard but it still did. now Im not really sure but is there a way to "reset" the tip over sensor or remove it or something. the bike sounds like it wants to start but it just isn't getting fuel and when I turn the key the fuel pump priming sound isn't there anymore. Any ideas or options are very helpful, thanks guys.
Old Mar 22, 2021 | 05:48 PM
The BAS (Bank Angle Sensor or Tip Over Sensor) is located below the windscreen. Remove that to access it. There is a procedure in the manual for testing its operation. Standing the bike upright and turning the bike off for a few moments and then back on should be sufficient. If it broke lose, then that may be your issue.
Old Mar 26, 2021 | 09:20 AM
Thank you sm I got it running finally it was a stupid mistake on my part, thank you again.
Old Mar 26, 2021 | 10:30 AM
Well it's ok if it was a stupid mistake, we've all done those. But please say what it was in case someone else does the same thing.
reaper101
Jun 15, 2015 03:37 PM
americancbr929rr
Aug 2, 2012 03:32 AM
jowyun
Sep 12, 2009 10:18 PM
DBEAU
Apr 17, 2009 10:22 AM
mac_z_28
Oct 2, 2006 05:48 AM
