throttle sticking?
Old Sep 7, 2007 | 11:33 PM
jwrocko's Avatar
Default throttle sticking?
when I shift down (to stop) the engine intermittently sounds like the throttle is sticking. - engine should be winding down as the throttle lets off and brakes are applied while downshifting, but when I get into second or first gear (on the way down), the enginedoesnt wind down as it should. I hope I am being clear with this - does anyone have any ideas?
Old Sep 7, 2007 | 11:39 PM
chpsk8er630's Avatar
Default RE: throttle sticking?
maybe try lubing the cable or check the idle.
Old Sep 7, 2007 | 11:40 PM
jwrocko's Avatar
lubing which cable? throttle? this problem doesnt happen all the time, so im having problems figuring out what it could be. wouldnt a sticky throttle cable stick most of the time?
Old Sep 7, 2007 | 11:45 PM
Im not really sure but it wouldnt hurt to lube it if you havnt done it. I lube all my cables when i change my oil. Its just a thought
Old Sep 9, 2007 | 10:15 PM
2002F4!'s Avatar
Loosen your bar end.
Old Sep 10, 2007 | 11:28 AM
IDL's Avatar
IDL
Maybe it only happens when the bike is cold so the revs remain in high idle?
Old Sep 10, 2007 | 02:02 PM
seebeeare21's Avatar
it could be tha fact that the bike is cold like idl said or the idle is set to rev higher
Jonnywright
Jun 3, 2012 07:06 AM
sawnee
Dec 20, 2008 04:44 PM
KLO
North East
Oct 29, 2008 03:01 PM
KLO
Oct 27, 2008 07:40 PM
SPoolinspOON
Jun 16, 2006 09:46 AM
