temp sensor, pc3 question
Old Mar 21, 2008 | 06:17 PM
StreetPower's Avatar
Default temp sensor, pc3 question
1) does the temp sensor always show some digits or kicks in after some lower limit temp? mine showed "--" at the ignition and at the idle (we let it work maybe for a minute, not more)..
2) does pc3 light up when you start the bike? or does it work without any leds/lights?
Old Mar 21, 2008 | 07:45 PM
dannutz's Avatar
Default RE: temp sensor, pc3 question
the temp display only shows the temperature when it reaches about 36 degrees celsius - i think that's somewhere close to 100 fahrenheit. that's about the same time the starting high idle should turn off and return to normal idle speed.
Old Mar 21, 2008 | 08:36 PM
bluej511's Avatar
96 degrees Farenheit and it should start coming on. Same as a car it doesnt start climbing until around 90 degrees.
Old Mar 22, 2008 | 04:26 AM
thanks , guys, i did assume it will be this way, interesting fact, i have a scangauge 2 in my car and while the arrow stands still the scangauge via the stock coolant temp sensor shows from about -3 degrees celsius...
Mark Dowsett Bugsy
Dec 19, 2014 03:11 AM
hss2010
Feb 12, 2012 09:54 AM
crow1
Mar 27, 2011 02:44 AM
johnnyx
Aug 8, 2010 06:44 PM
rdrink25
Aug 19, 2007 08:11 AM
