Taillight voltage problem
Old Mar 27, 2012 | 08:48 AM
nrmskate's Avatar
Default Taillight voltage problem
Okay, so long story short, I blew the LED's in my current taillight, so I tested the voltage that is being given off buy the running lights and the actual brake light. They both read 26v, arn't these taillights only made for 12v of power?
Just ordered another taillight and am trying not to put this one to waste as well.
Thanks!
Old Mar 27, 2012 | 05:02 PM
MadHattr059's Avatar
I'm not sure how you're running 26 volts, anywhere on the bike.
The max voltage you should be putting out is 14.8.
Are you sure you are testing correctly and in the correct range?
Ern
Old Mar 27, 2012 | 08:25 PM
nrmskate's Avatar
Yes, I can get a picture of it if you would like? If this is the case, then wouldn't putting a resistor in the running/brake light wires fix the problem?
Thanks Ern!
Old Mar 28, 2012 | 04:45 AM
My concern is how you're getting that much voltage in the harness in the first place.
I would take a look at the regulator/rectifier (r/r) and see if it is going out on you.
Look for heat damage on it and the wiring connector. Warped/melted plastic, burnt
pins, melted insulation on the wires, cracks in the epoxy-fill of the r/r.
The r/r should be regulating the voltage from the stator and if you are getting 26 volts
to your tail-lights, it doesn't sound like it is doing it's job.
Ern
Old Mar 28, 2012 | 12:10 PM
nrmskate's Avatar
I'm gonna feel like an idiot asking this, but where is the rectifier located? Can you get me a picture of where it plugs in? Thanks!
Old Mar 28, 2012 | 12:31 PM
estate4life's Avatar
February 2012 ROTM
RR locates right side under the rear fender cover....26V? I'm surprise the fuse didn't blew ?
Old Mar 28, 2012 | 12:56 PM
nrmskate's Avatar
A fuse blows because of to many amperes, not voltage, and thanks for the location of the rectifier, but where does it plug in at?
spicymeowmix
Sep 23, 2010 04:37 PM
gixxer130
Sep 6, 2008 07:06 PM
MC_spirited
Jul 9, 2008 06:08 PM
Woody6799
Mar 12, 2008 11:00 PM
NINE2NINE
Dec 17, 2005 05:38 PM
