tail light signals not working
Old May 18, 2009 | 10:54 AM
ali7up's Avatar
Default tail light signals not working
i just installed hot bodies flush mounts but i did not connect the tired wire, i also integrated singles into the stock light and now if i turn right the rear right bulb turns off, the front one still come on. any ideas thanks
Old May 18, 2009 | 07:19 PM
Zero1080's Avatar
It's gonna be your wires. I'd go back, and recheck, even if it means pulling off your elec. tape. I've done that and it has been the problem. If your other side works, make sure everything on the right is wired the same. my two cents.
Old May 18, 2009 | 08:24 PM
ali7up's Avatar
i checked back and followed the DIY thread https://cbrforum.com/forum/showthread.php?t=36151.The lights work fine but now the turn signal indicators in the dash stay on. And when the high beam is turned on the rear turn signals are weak.
CJardine
Sep 7, 2011 12:16 PM
madman
Feb 1, 2011 08:46 PM
Rennen
Sep 2, 2008 10:50 AM
kao600f2
Aug 23, 2008 12:46 PM
