How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Hotbodies Blinker + Running Light install
Old Apr 14, 2007 | 02:50 PM
bradfrd24's Avatar
Default Hotbodies Blinker + Running Light install
I wanted my hotbodies flushmounts to act as running lights as well as blinkers. So I played around with the wiring for a while and came up with this method. I wired up my 06' and my brothers 05' this exact way and it worked perfectly. I didn't show it in the diagram but You also need to wire in resistors for this to work! It gives you a little faster blink rate than stock, but IMO it looks better. Any questions just post here or PM me.
[IMG]local://upfiles/13280/6A21A51033A9442D89844B3BAD273819.jpg[/IMG]
Old Apr 14, 2007 | 03:02 PM
jjbtao's Avatar
Default RE: Hotbodies Blinker + Running Light install
Nice work. It's good to see others working on/posting info on this.
Another diagram of the same thing brought in from an older post: https://cbrforum.com/m_129799/tm.htm
Old Apr 14, 2007 | 03:44 PM
ChrisMcD's Avatar
Retired Admin
What level resistors are you running?
Old Apr 14, 2007 | 07:47 PM
bradfrd24's Avatar
20-25 watt, 8 ohms
Old Apr 14, 2007 | 08:08 PM
06CBRF4i's Avatar
will this work with short stalk LED signals too?? I am about to get some and I want to keep the running lights in the back..
Old Apr 14, 2007 | 08:31 PM
bradfrd24's Avatar
this set up will work with all aftermarket mounts that only have two wires coming from them (blinker and ground). It wont have any effect on your back running lights
Old Apr 15, 2007 | 12:05 AM
06CBRF4i's Avatar
im confused by what you mean when you say, " it wont have any effect on your back running lights." so it should work fine if I do this with the short stalk LEDs on the rear or no? thanx for the help/clarification
Old Apr 15, 2007 | 02:54 PM
bradfrd24's Avatar
Yes it should work with your short stalk if they only have 2 wires coming from them (ground & blinker)
Old Apr 17, 2007 | 02:16 PM
land_warrior.rus's Avatar
Looked at the way you wired the indicators. \one question though: when the running lights are on will the indicators blink???
It looks like the blinkers will just stay on if you have them on as running lights and blinkers at the same time.
May be im wrong...
Cheers
Old Apr 30, 2007 | 05:50 PM
axsys's Avatar
could someone explain better how this actually works? i know how to do it, but it seems like the light would just stay on all the time since its constantly getting a +12v from the running lights....... anyone know why the +12v from the turn signal lead makes the light turn off? thanks.
________
SELL VAPORIZERS
