tail light and turn signals stopped working
Old Sep 6, 2011 | 10:29 PM
CJardine's Avatar
Track junkie & modaholic
Exclamation tail light and turn signals stopped working
Hey all, so I was installing new turn signals. When I turned the bike on to check the connections, the left one worked perfectly and when I switched to the right one it worked for approx. 5 seconds before my dash, tail light and turn signals stopped working entirely. My head light works just fine and the high beam bulb lights up but nothing else on the dash does (including the neutral, back lights and the odometer). I don't have a fuse tester but would it mean one of the fuses was blown or maybe the rectifier. Also the PO installed a used set of aftermarket stalks and they cut the connections and taped it up I removed all the tape and redid the wiring with quick crimps until I can buy a fresh set of new connections.
I'd love your help because I was supposed to go on a ride with some friends in the morning.
Old Sep 7, 2011 | 07:43 AM
UnderAssumedName's Avatar
Solder those connections asap and just pull the fuses and see if they are toast. You don't need a tester. Just eyeball it.
Old Sep 7, 2011 | 12:16 PM
CJardine's Avatar
yea I want to redo the wiring cuz the PO just left the running lights wire just sit there plus they taped the **** out of everything. How many ohm resisters do I need as well?
Lucipher's obsession
May 10, 2012 12:01 AM
motomaniac18
Jun 4, 2011 10:52 AM
ali7up
May 18, 2009 08:24 PM
kao600f2
Aug 23, 2008 12:46 PM
mcvaaahhh
Aug 3, 2007 08:58 PM
