Turn Signals Stopped Working - Little Help Please
Old Aug 3, 2007 | 06:06 PM
mcvaaahhh's Avatar
Default Turn Signals Stopped Working - Little Help Please
My turn signals stopped working this week.
The switch seems to function fine, although when I hit the button either way absolutely nothing happens. Nothing in the gauges or in the signals.
The wiring harness seems to be connected just fine, and the hi/low beam switch works (don't have a horn so can't test that).
I went to the track last weekend and disconnected the signals, but re-connected on sunday and they worked fine for a couple of days and then went out.
Any ideas?
Old Aug 3, 2007 | 08:58 PM
alekinci's Avatar
Default RE: Turn Signals Stopped Working - Little Help Please
did you reconnect them back while the bike was on? if so, you might have blow a fuse. its a 10Amp mini. I would start there.
also, had cases where both my bulbs burn out for whatever reason. check them too.
lastly, get a multimeter with a ringing option and probe the turn signal connections.
Adescendant
May 28, 2015 07:09 AM
CJardine
Sep 7, 2011 12:16 PM
MrBlaze
Aug 17, 2009 02:07 AM
2QK4U2C
Jul 9, 2007 11:22 AM
mongoose2494
Sep 3, 2005 01:58 AM
