Tag Lights
Old Jun 4, 2009 | 12:28 PM
PlayfulGod's Avatar
Originally Posted by shawnyc01f4i
The ones where the bolt head is the LED? thats what I was thinking too but my question is how to wire it.
yup! You will still have to drill a hole for the wires to go thru or find one that they will fit thru thats already drilled. Then connect them to the wire that is there for the tag light or just splice into the ones for the tail lights. I have connectors on all mine so its easier to disassemble for whatever reason.
Old Jun 4, 2009 | 12:30 PM
florida f4i's Avatar
Like Aken said, just run wires straight from the battery.
Although wouldn't that keep it on all the time?
Old Jun 4, 2009 | 01:04 PM
shawnyc01f4i's Avatar
Thats what I'm saying, unless you put a switch to interupt the circuit. What I would like to know is what color from the tail lights will give me power only when I turn the key?
Old Jun 4, 2009 | 01:17 PM
PlayfulGod's Avatar
off hand I dont remember the color of the wires. I think the signals are green and yellow. A easy way to determine what wire does what is get a test light n poke it into the wires n see exactly what what one does what. And yes straight to the battery will have it on all the time.
Old Jun 4, 2009 | 01:23 PM
nor_cal_cbr's Avatar
Either wire it in utilizing the oem plate light wires...or just tap into the tail light, so it's on when the key/bike's on...super easy...good luck
Old Jun 4, 2009 | 03:13 PM
redzintimidator's Avatar
mine are LEDS in the bolts...$12 from ebay, just run the wires up in and connect them to the stock tag light wires, or any other constant on power source and ground.
Old Jun 4, 2009 | 03:16 PM
Thanks guys and Playfulgod, I'll do some net shopping and shouldnt have any problems with the install. Thanks again
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
