Symptoms for CCT replacement?
Old May 17, 2007 | 09:34 PM
HELLA's Avatar
Default Symptoms for CCT replacement?
Can anybody give me detailed descriptions of the symptoms that will let me know I need to change the CCT on my 02 F4i?
Also, how much does a shop charge to do the work? I know theres a detailed tutorial on cbr world, but if the labor at the shop isn't too expensive, I'd rather have a pro do it instead of myself.
P.S. I used the fabolous search function and only came up on threads that ask about installing the CCT, nothing about the symptoms tho confirm a bad CCT.
Old May 17, 2007 | 10:04 PM
rtbconstrictors's Avatar
Default RE: Symptoms for CCT replacement?
I am not an expert, i'm kind of new to sport bikes, but I believe that the symptom is a rattle between 5 -6 k sounding like BB's in a steel can. After 6 k I believe it stops fot the most part. I've talked to one shop when I was looking at different motorcycles and read that Honda's sometimes need cct's replaced and was quoted at about $1000.00 with labor included. That did not seem like a reasonable quote beings I've read in these threads you can did it your self at home in not all that much time.
[IMG]local://upfiles/13947/BA1F413201B9480EA061FC68807FA4EC.jpg[/IMG]
Old May 18, 2007 | 12:50 AM
SchiraF4I's Avatar
yea at home for about 3 bucks...but you make the choice 1k vs 3 bucks i dunno which way to go, i can live with the noise for now
Old May 18, 2007 | 02:02 AM
HELLA's Avatar
Thanks. Theres a big price difference, I guess I'll do it myself. If the noise is not a problem, what can happen if you keep riding with the noise? Sometimes when I'm in first gear and just coasting, it feels like the chain is rubbing against something, but there is no noise of it. It just feels real rough. But in every gear I will hear the "BBs in a cup" and feel the vibration until I get it up to 5 or 6k. I just hope my chain isn't going to fall off or anything that I can get hurt by.
Old May 18, 2007 | 02:16 AM
crunkchris's Avatar
i got quoted $100 with parts and labor, its a matter of taking the tank off, 2 bolts the tensioner is off 2 bolts the new one is on. maybe they thought you wanted to replace the cam chain.
Old May 18, 2007 | 04:09 AM
SchiraF4I's Avatar
From what ive heard only one bike had a freak blow up because of it...Ill take my chances til i have my tank off one of these days soon.. I'd only worry about it until you cant stand the noise anymore or if you are working on something else.
Old May 18, 2007 | 04:07 PM
HAVOC's Avatar
i have this same problem on my 2000 929and was going crazy trying to figure out what it could be. i started thinking if it was the cct ( on my previous 3 bikes it never went bad) how would i know it. but now im sure this is the problem
Old May 18, 2007 | 06:29 PM
philnyc's Avatar
Was this problem eradicated by HONDA factory on the newer F4i Models ?
jeff dunlap
Mar 23, 2013 11:38 AM
Michaud85
May 10, 2010 09:07 PM
packdog
Jul 29, 2009 08:33 PM
MC_spirited
Apr 8, 2009 02:28 PM
jwp6114
Jul 18, 2007 05:12 PM
