strange noise???...
Old Jun 25, 2006 | 10:27 PM
laybac's Avatar
Default strange noise???...
so i started up the bike as usual today. everything was fine till i got over 20mph. i then noticed a strange noise coming from the engine area. its really hard to describe... it kinda sounds like when you need new brakes on a car--not as bad--and only when in gear. its like a "shh shh shh shh shh". also, when i pull in the clutch handle and coast there is no noise. i did work on the bike piror to the noise. i adjusted the chain, tightned it up to specs. it was real loose before. any ideas to what this noise could be? could it be that i tightned the chain too much? [sm=helpout.gif]
*oops i should've put this in the trouble shooting area... move if needed. my bad.
Old Jun 25, 2006 | 11:46 PM
SkinnyJ's Avatar
Default RE: strange noise???...
did you at least check your pads to make sure there ok? other than that not sure. only when in gear....
Old Jun 26, 2006 | 12:24 AM
blinkster240's Avatar
could be the cam chain tensioner. its under the tank on the right side behind the frame it. makes noise only in gear around 3-5000rpm. i think everyone that has a 2001 f4i has had or will have a problem with the cct. ive replaced mine already. does it sound like a really fast paint can rattle?
Old Jun 26, 2006 | 12:36 AM
SkinnyJ's Avatar
yea but thats more of a click click not a shh shh shh
Old Jun 26, 2006 | 02:56 AM
laybac's Avatar
not the pads for sure. honestly i have no idea what it is. im gonna re-adjust the chain tomorow and see if that makes a diffrence. ive been thinking the worst here peeps, i sure hope it aint nothing bad.
Old Jun 26, 2006 | 04:20 AM
alekinci's Avatar
Dam, no one even answered you question. Crap. PADS?
Anyway. Readjust the chain and loosen it a link. Its possible that if its too tight you can have a different engine braking and stiffer cranking.
Which is possibly making that noise. If it was making that shshshshhsh thing while you were clutched in I would say its the valves. But thats not what it seems that you have. Readjust and check the oil glass. Hopefully its that.
Old Jun 28, 2006 | 01:29 AM
laybac's Avatar
well its not the chain. i still have no idea what it is. it has gotten worse. looks like ima have to take it in the shop to get looked at. dayum.
Old Jun 28, 2006 | 04:06 AM
alekinci's Avatar
Did you check the oil indicator glass? Is that fine?
Old Jul 2, 2006 | 02:41 AM
ejohn's Avatar
make sure when you adjust the chain that you find the tightest spot on the chain or you will make it too tight. also check to make sure you don't have any bad links in the chain.
Warhorse
Mar 18, 2014 05:15 PM
fireblade929
Nov 2, 2007 03:17 AM
CBRSQUID
Oct 29, 2007 06:06 PM
Spastik Monkey
Oct 29, 2006 01:26 AM
corrcullen
Oct 18, 2006 09:42 PM
