STILL having front brake trouble...please help!!
Old Jun 24, 2011 | 12:28 AM
Aken's Avatar
July 2008 ROTM
Really, the best way to figure out is to replace each part bit by bit with OEM. If you're using aftermarket, you could be getting more than one bad part. As others have said, even a little binding on the brake lever can make it start to lock.
Old Jun 24, 2011 | 12:55 AM
randyjoy's Avatar
This is a known issue with the eBay cheapo brake levers. I have personally seen it occur on several bikes over the last two to three years.
The lever is not quite the correct size, it prevents return flow and as the heat increases, it locks up. Only solution I've seen was scrap them and get better levers or take a Dremel to 'em.
Another thread
And Another
Old Jun 24, 2011 | 08:39 AM
coolcloo's Avatar
I think I will just dremel my current lever to make sure that's the problem, which is really all it can be at this point. Should the lever JUST touch the plunger? I'm just not sure exactly how much to take off.
Old Jun 24, 2011 | 11:14 AM
boredandstroked's Avatar
A stock brake lever is hella cheap, why do people go nuts for anything ebay/chinese made????
Old Jun 24, 2011 | 02:44 PM
coolcloo's Avatar
Dealer has 1 left in stock, going to pick it up after work. Will report back.
Old Jul 8, 2011 | 11:45 AM
coolcloo's Avatar
Well chalk another one up to cheap levers. Picked up an OEM lever and haven't had a problem since. Thanks for your help fellas. Now I've got to get rid of the entire brake system that I bought thinking that was the problem. D'OH!!
Old Jul 8, 2011 | 11:56 AM
supersnake83's Avatar
Glad it's now working correctly for you. I too have some cheap Ebay levers (carbon fiber levers) and haven't had a problem with them, but now I think I might just order some OEM levers and go back to stock.
I had to replace my levers when I went down 2 years ago.
Well, happy safe riding!!!
sktr9246
May 24, 2013 05:11 PM
zellster
Sep 26, 2011 09:39 PM
MrCBR600F3
Jul 21, 2009 04:08 PM
LIM118469
Oct 2, 2008 02:47 PM
truegrave
Jun 3, 2007 01:29 PM
