steering lock broken
Old May 8, 2013 | 07:25 PM
M1ke's Avatar
Default steering lock broken
Not sure if someone jacked withmy ignition cylinder while my bike was parked for winter but my steering lock is now stuck in the locked position. I can use the key to turn the tumbler and actually turn the bike on and start it but I cannot turn the handle bars due to the lock being stuck.
Is there any remedy for this or do I need to take off the front fairing to remove the cylinder and replace it with a new one?
Thanks
Old May 8, 2013 | 09:05 PM
Yin-Yang's Avatar
Theres two bolts holding the ignition, youll need an allen wrench and just take em out. Then you would have more room to see whats wrong. You also dont need to remove the front fairing or anything, but it helps to have small hands baby
Old May 8, 2013 | 11:30 PM
csimkalo's Avatar
Mine started sticking aswell after my bikes cover came off with me not noticing :-( sad panda but a little wd40 cleared everything right up
Old May 9, 2013 | 11:12 PM
M1ke's Avatar
Well I disconnected the front fairing stay that mounts on the neck and got plenty of room to unbolt the lock cylinder. Problem is, the cylinder won't come out even though it is unbolted. The locking pin is keeping it from coming out. See attached pics for what I'm talking about.
So is the only way to get it out to take off the top of the tree?
I tried pb blaster down the keyhole and on the locking pin but it didn't help. I can turn the cylinder fine with the key and even turn the starter but the locking pun doesn't retract.
Thanks
PS: All of the nicks and scratches make me think someone tried to steal this bike when a previous owner had it.... kinda sketch. I may just get a whole new upper tree along with a new lock cylinder to clean it up.
Attached Thumbnails steering lock broken-img_20130509_190027_287.jpg   steering lock broken-img_20130509_190041_564.jpg
Old May 14, 2013 | 09:33 AM
M1ke's Avatar
Anyone got any ideas other than taking of the upper part of the tree? Can I do that without a frame stand?
Old May 14, 2013 | 03:44 PM
M1ke's Avatar
Brand new complete lock set ordered, comes with ignition lock, tank lock, and seat lock plus a key. All brand new OEM pieces for $138 shipped.
Now just to get the damn old one out. Worse case scenario I will take the top fork bridge off and replace it with a nice shiny new OEM piece ($$$). It will up the quality of the bike in the long run.
Old May 14, 2013 | 11:13 PM
M1ke's Avatar
Ok another update, mainly for reference.
It turns out taking off the top bridge (upper or top of the tree) is very very easy. Loosen 2 12mm bolts to remove the handle bars, loosen the two allen bolts on the bridge itself and then the big steering stem nut. After that I could just pull it off with my hands and the broken lock fell right out. After reading the manual, it looks like I am missing the "fork stopper" at the top of each fork. I think they are just giant c clips. I will get those later on when I get a new upper bridge that's nice and new.
FSUNOLES
Sep 24, 2012 11:56 PM
p1squally
Apr 1, 2010 07:56 PM
crazycanasian
Oct 1, 2009 07:35 AM
ddaren
Aug 4, 2007 09:27 PM
cbr_newbie
Aug 31, 2006 11:47 PM
