Startup/warm up
Old 08-09-2006, 04:38 AM
Glocker23's Avatar
Default Startup/warm up
How hot should the motor be warmed up to after initial startup to taking off to ride?
Old 08-09-2006, 04:48 AM
Default RE: Startup/warm up
I hit it at 140 ish F
Old 08-09-2006, 10:43 AM
I usually warm up until the fast idle drops and the engine sounds smooth.
DO NOT rev the engine when you start it. This is the worst time for a engine because the oil has drained back to the pan and everything is cold and dosent seal well.
Old 08-09-2006, 12:25 PM
I usually ride at 115-120, but mainly after the high idle drops.
Old 08-09-2006, 01:36 PM
Tahoe SC's Avatar
i start it and go...yea it's not the best for the engine...cause all the oil's not moved around yet...so i take it real slow until 140ish.
Old 08-09-2006, 02:46 PM
Just to clarify that is usually only in the morning or at the end of the work day when the bike has been sitting for several hours.
If I come out of a store or something I just hop on and go. Again this is where I use the "fast idle" as a guide. If the ECU thinks the bike is cold enough to idle high, then it's cold enough for me to let it warm up.
Old 08-10-2006, 07:30 AM
Glocker23's Avatar
exactly ...the first start up in the morning or after work wen its just been sitting
Old 08-10-2006, 08:03 AM
its so damn hot this summer that i just leave at 120F
but on avg I usually go after 130F
Dblock55
11-29-2010 08:22 PM
Goose Rider
06-19-2008 09:17 AM
krobberts
04-11-2008 03:06 AM
Leveltwo
01-02-2008 04:52 PM
Zangetsu
12-18-2006 06:07 PM
Quick Reply: Startup/warm up
